Flat Spot Cured! - gotta love the simple fix
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/20200919_132817_1d7b215cf9ac2ea192b09c985b2ea85e6667d22e.jpg)
you know, for quite a while now I've had a flat spot or two on WOT acceleration. Didn't matter too much on the starting speed, the acceleration just bogged down. It was baffling.
Of course I checked and rechecked for air leaks in the convoluted air tube, nothing showed up.
Yes, I changed the fuel filter, seemed like maybe an improvement, but nah just the good old placebo effect. (At least it didn't hurt anything)
Then by chance I looked at the area I'm pointing to in the photo. The factory bolt was missing! It must have worked itself loose over time.
Well a quick trip to the auto parts store and $1.35 later she was secured. Its a 6mm bolt with a 10mm head on it fyi. A black flange bolt would have been better, the plastic has an oversized screw hole, but for now the silver bolt with a washer works fine.
I looks like the motion of the engine block under torque creates an air leak here.
I immediately saw a difference, nice smooth acceleration. FYI, performance seemes to have even improved after a few drive cycles! Big smile driving around today.
Guess I'm all excited about such a super cheap fix with such huge impact, we don't get to see this too often.
Maybe someone else will run into this someday.
John
The following 14 users liked this post by Johnken:
Abby's Guy (09-24-2020),
cjd777 (09-20-2020),
crbass (09-19-2020),
DavidYau (09-20-2020),
giandanielxk8 (09-20-2020),
and 9 others liked this post.
Johnken (09-20-2020)
The following 2 users liked this post by Jon89:
Johnken (09-22-2020)
