Hello All, new to the forum and would love some help if possible. I am going to manual swap my 2000 XKR and am planning to machine a custom flywheel to suit the S-Type six speed I have. I have not started the disassembly process yet and won't untill I have all the parts I need. I was wondering if anyone has a spare x100 flex plate that they could help me with some accurate dimensions? I am modelling a 3D design of the flywheel and plan on making it free for everyone to access once complete. Please see the attached image of the dimensions I need and the beginnings of the flywheel design.
The timing segments need to be AJ27 or the engine will not run correctly.
X308 sedan torque converter drive plate will work also.as long as it is AJ27.
Thank you, I plan on retaining the original flex plate with its timing marks. The new flywheel will serve as adapter to that and the clutch, much like the attached examples.
