Flushing 2002 XKR Radiator
The JTIS (jaguar technical information system) CD has as specific procedure, do you have access to this program? If you do a search on the forum, we have provided links to download, and create you're own CD. You must burn the disc, it cannot run locally from the drive...that we have found, that is.
Note before you get going: On the XKR you are going to need a humongous 19mm allen wrench socket to fill the intercooler. Its about 15 bucks from McMaster -Carr:
http://www.mcmaster.com/#5571a79/=7w5but
Yes, or you think about it for a little bit and finally end up inserting the head of a 1/2" or M12 bolt into the filler cap (both just happen to be about exactly 19mm). Spin 2 nuts onto the threads of the bolt and tighten then against each other. Then just use a wrench on the lower nut to unscrew the cap. Use the wrench on the upper nut to install the cap. Total cost, maybe a coupla bucks if you don't already have a bolt and nuts in your vast supply of new and salvaged hardware that you refuse to throw away and your wife rolls her eyes at.
I'm too cheap to buy a big stupid allen wrench.
Then, you'll need a few more posts before you have access. Just go to the Off Topic section and make a few mindless posts in the "never-ending word game" thread, or find some hot chicks posing with cars and post the pictures in the "girls with cars" thread.
Finally, you'll need a few days on the forum to have full access to everything. In a nutshell, you need a few days, a few posts, and then you can see it all. It's to prevent spammers.
But... if you'll PM me your email address I'll email it to you.
dtk (03-17-2016)
newbie, this particular document is hosted 'off-forum' and anyone can access it. Only the images and documents that are uploaded and hosted on the jaguarforums server require proper access by members. You can see these, as they show up as an 'attachment' at the bottom of the thread. It can be linked, however, within the text.
dtk (03-17-2016)
Well - it is probably bad form to admit to this group that I found another way - an on-line coupon from my local dealer to do a flush, test all, and replace fluid for $100 - including all labor and Jag fluid (materials)! I took it over and asked, and sure enough it was real!!
It took about 2 hours, and cost exactly $103 (including tax!), and it is all up to Jag snuff for 5 years!... (the service tech said it was about $250 otherwise)
DaleD
![Icon Bike](https://www.jaguarforums.com/forum/images/smilies/icon_bike.gif)
You're welcome RJAG!
I hope folks get the info they need from my docs and postings, as much as people have helped me over the years.
Stay tuned ... more coming.
Dan
Last year the dealer replaced my water-pump for the supercharger. Am I correct in thinking that would require fluid replacing also? I didn't see anything about it on the invoice and didn't think to ask at the time. Maybe they just poured the old fluid back in? I probably won't know for sure huh?
Dicque
09-19-2015 12:53 PM
