Foam between super charger and block
Old 09-11-2015, 01:41 AM
Super Cat's Avatar
Default Foam between super charger and block
I assume this is to keep the heater hoses from flopping around but seems like the foam would prevent air circulation and cause heat buildup leading to hose failure. What is expert opinion?
Old 09-11-2015, 08:14 AM
ccfulton's Avatar
Received 1,108 Likes on 764 Posts
There will not be much air flow in that area as it is completely surrounded by the intake, heads and supercharger. As such, everything will nominally come to the same temperature regardless of whether it is "insulated" or not.
I put it back when I had my supercharger off.
Super Cat (09-11-2015)
aode06
07-28-2023 02:26 PM
convincor
10-01-2015 05:19 PM
Lawrence
XJ40 ( XJ81 )
10-01-2015 08:36 AM
dieseldoc
09-28-2015 01:17 PM
sg997tt
Canada
09-27-2015 02:40 PM
Quick Reply: Foam between super charger and block
