It followed me home. Can I keep it?
The conventional wisdom is if a nikasil engine has made it this far, it should be OK. Gasoline composition was the issue back then and now we have different blends.
Resistance turning the crank
Thanks for the response. I won't worry too much about Nikasil issues, then.
However, I was reading another post from someone encountering a locked up engine, and one of the posts talked about being able to turn over the engine with a 3/8 stubby wrench. My engine takes a strong pull on a 24" breaker bar to rotate the crank. I just assumed this was a normal function of all the bearings and 8 pistons moving in the bores.
Should I actually be concerned about this? There was talk of bottom end issues with this car. I have squirted oil in the bores to keep thigs a bit lubed, but now I wonder about more problems.
TC
TC
euphoniaob
09-30-2015 10:50 AM
