The Folly of the Temperature Gauge
#61
Got back from my trip, to find my PLX DM 200 had arrived!. This is a commercial 60mm OLED gauge, that can show about 20 different 'standard' OBD parameters, and can also be hooked up to old school analog sensors.
Quickly hooked it up to the XKR this evening to see if it would work (it does) and how the gauge would look behind the center 3 hole panel that I had purchased. So far I'm pretty pleased. This is the 'standard' gauge, and it looks a lot better in the flesh than it does in the photos (in the photos the rectangular screen tends to show up, you can hardly see it in 'real life'). This is currently the 'standard' skin; I am going to experiment with a custom gauge, which can (literally) be anything you want. As you can see, it is displaying 'real' water temp....
![](http://www.thebytefoundry.com/xkrphotos/plx-web1.jpg)
![](http://www.thebytefoundry.com/xkrphotos/plx-web2.jpg)
I am still working with the home brewed Arduino (and now have that talking to the ECU); that approach is less expensive, and gives me more flexibility (I can do a Jaguar clock in the center gauge), but is a lot more work (though it's fun!)
The bad news is that PLX have just discontinued the DM200. The replacement (DM6) doesn't (IMO) look as good.
#62
Why did I just have a flashback from Michael Douglas and the turkey in the oven scene from "War of the Roses"?
#63
Thought I'd post a photo of the Arduino up and running with a hacked together Jaguar clock. I also have the OBD connection up and running, though it's not connected here (hence the clock). Note the LCD here is slightly too small (and has those icons on the right..), but is just for test purposes.
Having now confirmed the PLX works with the XKR (last post) and also got my 'home grown' version, I'm considering exactly what to do; I'm considering 3 screens (one to replace each gauge). Center one would be a clock, but it would also monitor OBD, and if any 'alarm' conditions came up (or DTCs) would display them, and perhaps allow reset.
![](http://www.thebytefoundry.com/xkrphotos/Jag-Clock-OBD.jpg)
Really, I'm just playing here, but now I can get the data on the Arduino the world is my oyster...I welcome any suggestions. Output doesn't have to be LCD...
I've been trying to find if anyone makes a ROUND (or small square) modern GPS/SatNav - if the video for that was switched to one of the gauges that would be perfect...
-Steve
-Steve
#64
Very cool!
Even though you are talking to the ECU now, you may be able to reduce your R&D effort considerably by using one of the ELM interpreter chips between the ECU and the Arduino: Elm Electronics Products - OBD ICs. Have you considered that?
#65
Very cool!
Did you see the post on the DM-200? That works pretty well, but isn't that user friendly to set up for a custom gauge (you need 100 separate images, to cover 100 'frames' between max and min. However, that does give you almost infinite flexibility in what it looks like.
Steve
#67
Yes, I have been looking at various options.
The best (and most costly) is to have new gauge faces made.
A custom dry transfer decal will be less costly, but will not light up at night.
A third alternative is to leave it as is, and tap into the LCD display to provide the precise readings electronically.
Comments and ideas are welcome!
#68
#69
I need to take precise data on what the existng system calls 'normal' and 'redline' and factor that into the decsion along with a desire to have nice even numbers and a linear display if possible.
Funny this topic was raised today...time has been scarce lately but I am actually working on this project today.
#71
I hustled the last two weekends to get this day.
My wife's notepaper BTW:
Hatley Store: Hatley Nag Nag Nag Magnetic List
![Icon Dance Twist](https://www.jaguarforums.com/forum/images/smilies/icon_dance-twist.gif)
![Icon Goofygrin](https://www.jaguarforums.com/forum/images/smilies/icon_goofygrin.gif)
#72
Good question...I have not decided yet, but since it is controlled by a microprocessor I can make it behave any way we want.
#73
Based on popular demand on the forum and on my website, converting the fake water temperature and oil pressure gauges to real ones has soared to the top of the list for the next 'thejagwrangler.com' product.
As a result, I spent quite a bit of time over the holiday break working on this project. I am happy to say I have built a proof-of-concept test fixture, written software for it, and demonstrated that I can take complete control of the Jag's stepper motor based gauges. I have also confirmed a suffiicient source of supply for one needed component, which is no longer manufactured, but without which would make this project much more difficult.
I am now ordering parts for a complete product prototype and investing in a large lot of this one part which is out of production. I hope to have an easy to install product available this spring at a reasonable price point. Once the prototype is ready, I'll post pictures and more details.
Thanks to all of you who have already purchased my products....you have made the continued development of new XK8/XKR products possible.
#75
#76
Whitey;
Will this accurate temp gauge display through the three gauge digital version you have done for the Nav. Screen?
Could set it to flash and override the Nav/Clock screens if anything requires immediate attention. Or a small flashing icon in either of those screens.
Sign me up for one too please.
As a one of the 'idiots' who cooked an engine in a '67 420 when I was crossing Nevada in my college days on the theory that 130 degrees was not much....Celsius gauge....RHD import...no red line....I am fairly keen on accurate gauges.
Since the top tank had a leak the shop, 'Isis Motors' of San Francisco, eventually had it towed from the middle of no where, Tonopah Nevada, back to SF and fixed it but it was a hard and expensive lesson for a guy on a college budget.
Not keen to repeat the experience.
cheers,
jj
cheers,
jj
#77
Whitey;
jamjax (01-04-2012)
#78
Whitey Thanks;
I like the three gauge screen and the utility of switching from that to Nav. to clock.
Like the new glass cockpits on airplanes now...
Hoping to get you over for the Loire Valley-Bordeaux Rallye this summer and I am sure there are going to be enough guys to keep you busy....if that is what you want...or to have a tech day.
Along with the car detail guy from the west coast who has shown some interest.
Now if I can just get XKRacer and Avos to come it will be a full house.
Just put me first on the list please for the HKS/Garmin upgrade and the cool roof remote, sure makes getting in the car easier with the top down...or out for that matter. Better have the 'resistor' interrupt for pressure spikes on the roof hydraulics as well.
cheers,
jj
cheers,
jj
#79
#80
SPIJohn (01-06-2012)
