Forgive me, Forum, for I have sinned (and now I want a meaty exhaust)
Hmm, hunting around the forum, I have also come across electric cut-outs. These are new to me, but they appear to offer the ideal solution, i.e. quiet when you're taking the wife out for dinner and then loud when you want to have a bit of a thrash. Does anyone have any experience of these on their XK8/R?
But, one of the biggest limiters of sound ARE the factory cats. Replacing them and you'll get much better exhaust note. And, if you keep the rest of the exhaust stock, your exhaust tone will be quiet if you want to drive mild and will sound great if you floor it... all without having to push a switch.
My main complaint would be that the exhaust cutouts will eventually rust, the seals will eventually give and the motors or electronics will eventually die leaving you with another set of possible problems to repair, while the cats should last the lifetime of the vehicle.
Frog (06-15-2013)
New Exhaust
There are many options depending on price, retaining the old exhaust just in case and your ability to fabricate. I chose the Mina exhaust because it takes about an hour to install on a hoist. You take the OEM exhaust off behind the converter and save it. This system system is stainless steel and bolts right up. It eliminates the resonators and the pipes go under the axel in stead of over the mufflers fit right where the old ones did with no modification to the car. You have a choice of quad tips or two oval ones. The sound is a lower pitch growl but not much louder. I was pleased. The price is about $900.00. Good Luck
The instructions are right under your nose, on this very thread. See my earlier post... there is a PDF attached!
Frog (06-16-2013)
So, unlike most other exhaust mods, you're really knocking two proverbial birds with one proverbial stone and if you're not happy with the sound of your exhaust after the cats, you can always remove the two rear mufflers or add a Mina or other kit.
Even guys with cars that could smoke mine outright get really nervous when they hear me rev... they often give up without a fight... or rather, a stoplight race. lol
Oh, and I've had looks of sheer terror after reving alongside Boxter and M3 owners who think their cars are sporty.
Frog (06-16-2013)
#28
I think that's the best option, personally. You can do a whole bunch to the back end of your exhaust, but everyone who does that is actually trying to get rid of or compensate for the horrible tone-sucking cats.
#30
#31
Frog (06-17-2013)
#33
No, I just used some straight-through pipes I found on UK eBay. They were only about $200 and easy to fit, but only made a slight difference to the overall sound. More like having the volume turned up 10-15%, rather than an actual change in the exhaust note.
#34
Larini is your salvation then, my son. ^_^
Larini is a world-class exhaust manufacturer, they build some of the best sounding/looking exhaust exclusive to higher-end luxury and exotic/sports cars. They're not going to be cheap (1800 USD I think for the full exhaust) but they'll be worth it with, not only, a gain in hp of roughly 20~ but in sound too. Here, they have two sound notes, characteristically made different for different drivers. V1 is a little more timmid and reserved than V2 but still meaty and throaty on WOT while V2 will give you that no-bull-sports-car sound. Check them both out here, they'll have clips of both versions of the exhaust as well as half-exhaust options. Exhaust upgrades
Aus V8S
11-13-2015 11:01 AM
FS[NorthEast]: HOT Black/Black '07 S-Type R w/55k miles for sale!
08Z06
10-24-2015 05:46 PM
center, exhaust, front, meaty, muffler, noise, plate, sound, throaty, weight, xk8, xk8muffler, xk8mufflercat, xk8mufflersingle, xkr
