Found a promising used XK8 convertible: what should I look out for? Details follow
Here comes the details:
I think I can get it for about 9k, any ideas as to what to look for with this particular car? I've read about "usual suspects" in other threads
Thank!
Jagosaurus
- 2000 model. Looks awesome, dark blue with a black canvas top.
- VIN SAJJA42C2YNA02688
- Owner has had the car since 2003, one previous owner.
- Has been serviced by & sold by British Motor Company in San Francisco.
- It is a second car so only goes out in fair weather. It is garaged.
- The timing chains were replaced [metal replaced the original which I understand were plastic & were prone to problems] when the engine was replaced in 2004 at 41,000
- Transmission assembly was renewed in 2005 at 49,000 miles
- The hydraulics for the roof were replaced 2006 at 55,000 miles
- All work has been carried out by British Motor Cars in SF & Hills Motors in San Carlos
- Recent works include regular service, & minor adjustments & checks.
- All maintenance records available
Thank!
Jagosaurus
You appear to have two of the major issues covered. An all encompassing list of used purchase issues specific to the XK8/R can can be found there:
https://www.jaguarforums.com/forum/s...38&postcount=5
Other links on common problems can be found at the top of the forum at the top of the FAQ Sticky.
Sounds like a well maintained car at a good price. Any paint or interior issues? I would suggest that you look at the Owners Manual for the feature operations and check each one; power windows, seats, seat heater, A/C operation, etc, etc. Remember that a failed A/C in a car like this can cost as much as a transmission to repair.
The one special attention area I would suggest is the front suspension. Check for uneven tire wear, shimmy at all speeds, clunks over small bumps, etc.
Good luck in purchasing an used car is a result of due diligence.
First, does it pass the smog test?
What is the current odometer reading?
Will the seller let you take it to the independant Jaguar shop on Valencia St. to check it before you buy it?
With several major parts being replaced, check that they were not replaced with used parts of unknown quality.
Read about how some transmissions can lurch when coming to a rolling stop and then trying to accelerate briskly.
Go for a test drive to see if you like the ride and the steering. The tires & wheels do affect it. Take turns driving, so you can observe & listen when the other person is driving.
99xk8guy
06-05-2023 06:28 AM
