French Rear Number Plate
Hi Graham,
sorry to trouble you again but I have a totally unrelated question - I have to take off my UK plates which are held on with some sort of plastic fastener and replace them with French plates which "should" be pop riveted on. I am not sure how to remove the UK plastic bits at the rear. Do I have to remove the boot lining to get to the back of the plastic piece?
I guess if I pop rivet on I will have to drill through the body
Sorry still have not found how to post a new thread
Thanks again in advance
The square number plate fixings can be removed by putting a self tapping screw in and pulling the fixing out with pliers but it's much easier to release the boot liner with a trim removal tool and push the fixings out from behind.
If you must have the French Registration Plate pop riveted then you really need to see what you may be drilling into and in this case releasing the boot liner is the safest way to go.
If 'Frog' sees this thread, I'm sure he'll have good advice on acceptable ways to fit French Plates.
You need to install the number plate changer, ala James Bond. If for nothing else, out of principle....
Take care,
George
I confirm that French plates should be riveted on. However, as a point of principle, I refuse to do this on my nice cars and use extra strong double-sided tape instead. This avoids deforming the plate and drilling a hole through the boot lid.
Touch wood, no one has noticed yet, not even the policeman that stopped me this morning in my Mini for speeding
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Touch wood, no one has noticed yet, not even the policeman that stopped me this morning in my Mini for speeding![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Take care,
George
![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
Did you get away with the speeding?
I got flashed by one of those in August, the indicator sign wasn't working but I was just slowing to 90km/h the road having changed from dual to single carriageway. As I looked at the speedo dropping below 60mph there was a flash in the rear view mirror! Fortunately I was in a UK registered car so no comeback for it.
Tar
09-06-2015 11:24 AM
