Freon leak on compressor 2001 XK8
It looks impossable, but it can be done. I did it from under the car using a couple of extensions, probably 18 to 24 inches. I came in from the back by the Cat and went up beside the motor mount. Probably had a universal on the end by the socket.
When I got the nut off, I pulled it out just enough to get the o-ring off the tube. I used a pick like tool to pull off the old ones and hook the new one over the tube. I think I used a long needle nose to hold the nut in place as I came back in with the socket and extensions from behind.
Once you find the path for the extensions, it is really isn't as daunting as it looks.
Good luck.
Good luck.
