Front ABS harness problem -Resolved
I think my front ABS harness has a short in it as every time I make a hard left turn, the ABS light comes on. A year ago, I had the issue and the dealership said the sensor and harness was bad. The warranty company would not let them replace the harness so they just changed the sensor. The light did stop coming on for awhile but now its back so I think I'll change the harness. To take it back to the dealer to find the problem means a $100 diagnostic charge plus the $100 waranty deductible, so I'll take the chance it's the $50 harness. If I'm wrong, I added $50 to the cost of fixing it.
Does anyone know where the harness attaches to?
On my 97 the left side is just aft of the windshield washer fill neck and under the brake lines. It is easier to remove the connector assembly from the mounting clip and then unplug. The right side is easier to see on the wheel well in front of the suspension mount. Of course, yours may be different.
You will have to drive for a few miles before the light goes out, but I don't think you have to have the code cleared.
RJ___________
97 XK8 86K mi
RJ___________
97 XK8 86K mi
oldmots (10-07-2012)
Received 2,193 Likes
innzane
09-02-2015 10:08 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
