Front anti roll bar links and bushes
Hi. I was getting a squeek from the front drivers side and the garage showed me under the car and when he pulled on the anti roll bar you could hear it squeek and see the anti roll bar moving about so he said i needed to replace the bushes and stabilizer links either end. So i did. And on my test drive after a few hours fiddling about i still got the squeek!!!!!!!!!
Any other common places to check. It sounds like the noise is coming from thedrivers side only when i go over a bump in the road and also if i am cornering fast i can hear it. Soooo annoying after replacing what you think is the problem
Check your suspension top mounting bush - they make a sound like birdsong when they are going out. If the shock absorber top bolt is off centre chances are that's the problem. If your car is a convertible then the cross braces under the bonnet can also work loose and make a similar sound.
aholbro1
08-05-2021 05:02 AM
carcycle
09-07-2015 10:22 AM
