front ball joint / seperator
Question, I'm pulling the front apart to replace bushings etc, I'm trying to remove the lower ball joint using a Hfreight claw style bj clamp, I find the bj shank it too wide to fit the claw in, I'm considering grinding the jaw a bit wider but wanted some input first.
2nd question: the rotor shield appears to be seated within this balljoint shank, when pressing the new one in did you do this or just cut the tab on the shield ?
Tap the push point with a hammer gently as you tighten.
Gus
www.jagrepair.com
Gus
www.jagrepair.com
jamdmyers (12-15-2015)
Received 2,193 Likes
XxSlowpokexX
12-03-2015 05:18 PM
