Front brake piston retracts all the way?
Guest
Posts: n/a
Hi Guys,
I'm putting new front brakes on my 98 XK8.
Question, does the brake cylinder retract all the
way in?
Mine is protruding still about 1/4 inch, which is
keeping me from placing the caliper back on with
the new pads.
I thought I'd ask before I apply more force.
Also, I have let out any pressure that was in
the brake lines.
Thanks for any info/advice!
way in?
the new pads.
the brake lines.
Guest
Posts: n/a
Update:
Ok, I talked to a retired mechanic and he assured me that the cylinder should
retract all the way to be flush with caliper assembly.
I put a tremendous amount of force on them and they would not budge
any further and are still about 1/4 inch raised.
My only other thought, besides the cylinder being frozen, is that the
pads I ordered are somehow oversized. The "pad" on each brake
is 1/2 inch thick. Is this correct? I'm guessing so...
The caliper bolts were extremely hard to get off also, so I won't
be surprised if the cylinder is indeed frozen.
My next step is to reassemble with the old pads and take it to a trusted
mechanic and have him rebuild the caliper, unless someone has any better
advice...
Thanks for any info, obviously I'm a bit of a
novice. Great to be learning though, lots of great info
in these forums.
advice...
in these forums.
KarimPA
09-12-2015 08:15 AM
