Front Door Speakers - Standard Audio System
Can anyone provide me with information on a direct replacement for the 6.5 inch front door speakers? If someone has gone though a similar upgrade in the past I would like to know where I can find the exact same speakers. If possible, I am looking for matching screw holes while not having to cut anything out. Also looking for a matching plug but if not I can always solder the wires back on. Thanks.
The standard speakers were made by Philips - at least they were on my 2001MY XKR.
Most decent 6.5" mid/bass drivers should include a ring to allow you to mount into the existing screw locations on that plastic moubting ring. You will have to solder the connections.
Have a look on Talk Audio Online Car Audio Magazine & Forum for some reviews. The editor of the site is Adam Rayner - top bloke.
There is a lot of info in the Audio Section.Take a look at this for aa upgrade-
https://www.jaguarforums.com/forum/a...-%24500-40495/
Good luck with your project.
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Do a search on speakers and get informed on what others have done. It's not the watts that a speaker can take that makes the difference.
A higher wattage just allows the speaker to take more power. Generally, higher is better, but it won't make them louder or better sounding. 6.5" is a very common size-- I'm sure there are plenty of options. I expect that this is a multi-speaker system the impedence rating may be unusual. Normal speakers are 8 ohms, but I would not be suprised if the OEM ones are 4 ohms. Does anyone here know? I haven't taken the door apart to look. An impedence mis-match would make them possibly sound bad. I would look at "Crutchfield" online. MC
I've just upgraded my front speakers (along with the rears and an amp, sub to follow!).
I fitted Infinity Reference 6.5" components, with 1" tweeters up under the dash grilles, on my 2004 coupe.
It would be easier on an earlier car to fit the tweeters to the top of the doors (and to be honest I don't think there'd really be all that big a difference in the sound quality), keeping the crossovers in the doors - there's loads of space - and using the existing speaker wires as the feed into the crossover. I don't think your car has the tweeter and dash wiring connected at the main harness.
To install the 6.5" drivers, I used a flapper-type sanding wheel and eased around 3mm out of the inside edge of the factory plastic mounts for clearance, using the lower screw as my reference point to align the speakers to. I then simply drilled 3 more small pilot holes in the plastic and fitted the speaker with one original jag screw at the bottom and three supplied with the speakers after applying the supplied sealing foam.
The jag's door speaker fitment is actually quite a good design as the plastic fitting is foam sealed to both the speaker and the door, providing an excellent baffle, making the door an almost perfect enclosure to give the speaker something to work against other than simply free air.
The improvement in sound clarity and bass response was excellent, even before I fitted the amp!
MC36
US Lower Atlantic
09-01-2015 07:34 PM
