Front hub removal question
I'm going to be replacing my front wheel bearings on my 2005 XK8. I want to remove the hubs and take them to a shop to have the new bearings installed. From what I can gather, in order to remove the hub assembly I have to pop the upper and lower ball joints, the tie rod joint and the speed sensor on each wheel. Does the assembly then just slide off the axel or is it more involved than that? Thanks for any info.
Stamford (03-29-2023)
Yup, calipers, etc. will come off. Hoping the unit will then just slide off the axel. Will probably take the opportunity to paint the calipers red and the wheels gloss black. Think that will really look great on a silver car with a black top.
Received 2,434 Likes
The following 2 users liked this post by michaelh:
Stamford (03-30-2023),
Superchargedxkr (03-31-2023)
The following 3 users liked this post by Stamford:
yardpro
04-03-2022 08:11 PM
