Front license placement
So the other day when the Travel Channel was going to film in our automated parking garage, I cut the zip ties that held my license plate to the mesh grill in front of the bumperettes. It always bugged me as it hides the very attractive opening, and when I took it off, it was sort of a liberating feeling. I have driven it around the last couple of days wondering if I would get stopped and readying my excuse that it had been used in a tv filming, and I hadn't had a chance to put it back on. I thought about copying the license onto sticky backed vinyl and putting on lower lip of bottom opening, but I wasn't sure this was an allowable substitute plus if it wasn't I didn't want to have to scrape it off. So, I came up with another solution. I haven't finished it yet as I just put it on a few minutes ago, and now I will make a couple of plastic sleeves that will cover the screws and which I will paint the same Cardinal Red as the car, and I don't believe it will be noticeable unless you are inches away. I took 4" long 1/4" diameter bolts, poked them through the license and frame and through the mesh about an inch up from the bottom so that the screws came out relatively straight, reached behind the grill with two washers and nuts, and simply ratcheted it tight. Although it appears low, it is not as low as the bottom of the lowest point of the bumper or the protective plastic piece under the radiator. Tomorrow I will make the sleeves out of either plastic or metal tubing, paint and install. It might not be better than no plate, but it won't cost me a $200 ticket. And yes, those are my big feet in the last photo.
Anyway for 13 years I had driven my Corvette without a front license plate. Things like that and window tint were only usually cited if you were stopped for something else. Well in my 14th year I had a cop chase me down SOLELY for no front plate. Since then I have heard of folks getting ticketed at night with their car parked in front of their house. This type of chickensh*t stuff is easy revenue for the jerks that mis-spend our money. The out-of-pocket cost for addressing the plate situation was maybe $25 but it wasted a few hours of my life.
So when I got the Jaguar it did not have a front plate and I drove it a couple of weeks like that. But every time I spied a cop somewhere it made me nervous so I just bit the bullet and mounted it using zip-tie but lower than it should be so as not to block the mesh grill.
Doug
Well, I have had it in the lower position for a couple of days, and it has scraped the bottom a few times. I think I am going to cut about an inch off of the top of the plate as well as at the bottom. The numbers and letters will still be unaffected but the license will be shorter by a couple of inches. I will drill new top holes in the plates and then fashion a frame and a bracket to hold it. I like it below the grill, and I'll find a way to make it work.
Hi George,
Feeling better? I thought about putting the plate in a vice and bending "flaps" back against the back of the plate rather than actually cutting off. If I can lop an inch and a half or so off the plate and scoot it up, I think all of the scraping issues will go away.
See you soon.
Ted
See you soon.
Ted
Tirefriar (03-20-2013)
another member put a retracting plate holder on his car. I bought it but haven't installed it yet. It's electric and uses a key fob.
Here is a video of one working:
Delayed putting it on because my car is lowered and I'm a bit worried about grounding my plate out on a steep driveway but its on the list. Both Amazon and eBay has these. About $120.
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Before I bought our car it had been registered in 3 states that required front plates for a total of 15 years. I had it for 10 days and had the front plate laying on the left side of the dash. I was trying to figure out how I was going to mount it. You guessed it, I got stopped but luck was with me and got only a warning. I went right home and made a quick decision on how to mount it. Now I can drive around and not worry. Our son a few years ago got stopped 3 times with his Mustang for no plate, he simply never learned.
2 small sheet metal screws up under the spoiler remove it easily if I enter any show or event.
I can always bend it flat again if it becomes an issue re: defacing government property.
