Front Main Seal Leak, how common?
Congrats to all y'all with Bin Laden's extermination and Obama's re-election! However it did not fix that oil leak, I am having from under the engine front.
It seems that every morning I see about 2" in diameter oil drip on the garage floor, plus front motor cover has oil around the main seal, leaking down onto subframe and such.
How common are the front seal leaks and is there something else to look for, perhaps?
I've got the same small oil leak. I have receipts from the last owner
for seal replacement of; crankshaft front seal,timing cover gaskets inner & outer, spark plug seals, center cam cover seal, cam cover gasket left and
right, cam cover bolt seal,front engine seal, pan gasket seal and with all that money he spent it still has the same small leak as yours. The oil leak amount is so small I don't even add oil between 5k mile oil changes. So, I
just live with it.
Regards,
just live with it.
![Icon Bike](https://www.jaguarforums.com/forum/images/smilies/icon_bike.gif)
Regards,
MC36
US Lower Atlantic
09-01-2015 07:34 PM
