Front Shocks - how to release?
I hope this isn't a dumb question but I can't figure it out. I'm going to put in new OEM front shocks tomorrow, but there are no instructions. Every other shock I've seen before is held in a contracted state by a safety wire. These don't have one. How do I release them so they can move when installed? They seem to be in a locked position right now.
Thanks,
John
Thanks,
John
Received 2,688 Likes
If you are doing this procedure remember you will need to compress the springs to get the new shock in, which can be done depending on what tools you have but it's a real pain. Many have taken the old setup with new shock(springs) and had a shop do it , they appear fairly reasonable priced. I know when I replaced my shock mounts I was 'surprised' as to what it took to get the springs compressed enough, I felt like I was working on a bomb.
Thanks JamMeyers, I know what you mean. I was able to borrow a spring compresor, but this is my first time. It will be interesting. You know the outcome will be worth the effort, I'll let you know how the improvment helps (front socks/ front shock mounts). I'll be getting to use my compressor's impact wrench for the first time too.
I would consider replacing the coil springs while you're at it. Have to take them off to replace shocks and top shock mount anyway, so it saves the labor later.
And if your front end is down more than 1/2 - 3/4 inch from normal (15.75 IIRC), you likely need new coils.
BTW, I highly recommend having a shop do the compression and replace. It is dangerous if you are not very careful and most shops will charge around $50 for the pair. Well worth it IMHO.
Regards,
Tom
tlynch (09-22-2015)
With some poking around I discovered that multiple of the forum sponsors have coils springs for the XK8.
Tom
Guy-Pierre Boucher
09-16-2015 05:55 PM
KarimPA
09-12-2015 08:15 AM
Tar
09-06-2015 11:24 AM
