Front Sway Bar-clunk
Received 2,190 Likes
Just order a set from Discount Auto Parts Online -- PartsGeek.com - Domestic & Import Auto Parts Warehouse, theyre cheap
The bushing size will be dictated by the size of the sway bar. If your XKR came with the handling package upgrade you will likely have a larger sway bar up front and smaller in the back. BTW, while you are replacing the front sway bar bushings you may want to also do the backs. They are much easier to get to and not very $$.
if you want poly, theres a company over in the UK that makes purple ones (sorry can't remember the name, polyflex I think. ) , otherwise, if you want good rubber, get an OEM pair, literally it'll be less than $40 out the parts door. They are shaped a little different than 'universal' ones...get it trimmed wrong, and you'll ruin the whole bushing...trust me, i've tried it.
