Front upper shock mounts/ ride height
In December the front ride height was 14 1/8 Left and 14 5/16 Right. I replaced the upper mounts and shocks, and also put a 3/8 spacer on top of the left mount. After about 200 mi. I now have 15 1/4 Left and 15 3/8 right, a lot closer to the 15.74 spec., and better than I expected. Those yellow pads were really compressed.
Now to get alignment done in case the toe in is off.
I thought the nylon spacer would raise the left side more than the right, but it is what it is,
OEM mounts are junk unless they are the upgraded urethane units.
Welsh Enterprises, Inc - Jaguar XK8 / XKR (97-06) Front Suspension Parts - Front Shock Mount Bushing Kit - Urethane - XK8
Received 4,303 Likes
RJ, from what I've read regarding the OEM mounts - they should last around 100K miles. I noticed the foam disintegrating around 100K but didn't think anything of it until the front end noticeably dropped and the car developed a loud squeak from the shaft of the shock contacting the chassis. I went with the oem mounts from Welsh and so far am pleased but it's only been about 6 months or so.
KarimPA
09-12-2015 08:15 AM
Tar
09-06-2015 11:24 AM
