Front wheel bearing life
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
With my XK8 2000 and 45,000 miles on the clock what mileage would I expect to have to replace the front wheel bearings? The car has been a daily driver since I have owned it ( little over two years) and is driven in a very modest way mostly by my wife. And with it being a 2000 year would I expect the bearings to be the upgraded 80mm size?
Thanks for you help guys.
EZDriver 2000 XK8 1995 XJ6
I've always found this tough to describe. It's a sound like a heavy dry solid metal object rolling along a concrete floor, rough yet rolling, and it increases with speed both in volume and pitch (perceived frequency). the worse it gets the louder it gets. Did that make sense?
A test you might try, although I've only used this on front wheel drive. While rolling along a wide road with no traffic, swing the wheel side to side making S-turns. The noise from the bearing will change depending on the direction that you're turning. Sometimes as bad as OFF-ON-OFF-ON as you go from side to side. Don't be so aggressive that you get the tires to make noise, just looking to change the load on the bearings.
Skid Mark (03-24-2012)
With my '97 at 115K, and not knowing if they were ever changed, I have tried some static testing to see if I could hear anything. Wheels off the ground, spin at different speeds, stethescope, 6-12 and 3-9 rocking, etc. I don't hear anything that way, and sometimes I "think" I hear noises on the road, but it could be my tires, the road, or other things. If I ever get to replacing the sway bar bushings I'll give it some more road/load testing.
innzane
09-02-2015 10:08 AM
