Front windows won't go up
I knew this was a problem in waiting. The window moves down a bit to pass the convertible top and when the door is closed it goes back up. Well today, that stopped working. Pull on the knob and the window comes down a bit, pull again, a bit more, etc.
Did have the battery disconnected while doing the purge control valve.
So I am guessing that a sensor someplace is confused, how to I make that sensor happy again?
On the XJ40 all windows will go up with the key turned to the left but that doesn't seem to work on the XK8.
Any ideas?
Any ideas?
Received 6,311 Likes
rwho, in their rush to advise you on HOW to correct the problem, they neglected to explain the WHY.
Allow me. <clears throat> When the battery voltage is drained to a low enough level, or the battery is disconnected as required for safe maintenance like you did, the windows will lose their programming. When the battery level falls, the memory in the windows is always the first to go...making it a good telltale sign of a weakening battery so you can start saving some of your lunch money for a new one.
Discussed extensively. Bad "Door Open Switch" connected to the outside door handle assembly, but inside the door.
Here's an explanation of the bad door switch and a video on how to replace it.
https://www.jaguarforums.com/forum/x...deo-faq-50532/
99xk8guy
06-05-2023 06:28 AM
