Fuel cleaners/additives
For the last several cars I have owned (all of which had fuel injection), I got in the habit of adding a can of fuel injector cleaner or fuel system cleaner or octane booster every now and again. Do any of you folks do this and is it okay or something that should be avoided with Jaguars?
Thanks,
Doug
Thanks,
Doug
Thank You! I change the oil every 3,000 mi, I fix what is broken, I add BG 44K about every 6mo, I check the obvious and drive the hxxx out of it. I run it hard and we take it everywhere. This car loves to be driven! The most important part of what I do is check many chat rooms to see the problems other people have and use what I learn and be proactive. My being proactive came from working on aircraft, no room for error. I have never replaced the trans fluid but plan to do so this spring. The expression “If it aint broke don’t fix” it is true. However, examine it and make sure.
You can get it at most dealerships or high end repair shops. E-bay is an option as well as www.motorcarsltd.com
WTB[SouthEast]: 2000 XJR door seal
moff1959
09-26-2015 05:35 PM
XKE73EIconverter
09-26-2015 10:21 AM
