Fuel Feed Hose Replacement part
hi all,
What are the options for replacement Fuel Feed hoses?
I have a major leak in the fuel feed hose to the injector.
The hose I pulled off the car today is part # NJA-6053AD (DISCONTINUED)
Further inspections shows one of the internal o rings deteriorated.
I was advised to replace this with part# NJC-6053AA
Our former Jaguar mechanic said they are no longer available and buying a used one is my best option.
https://www.motorcarsltd.com/used-njc6053aa.html
Are there any other options here?
thank you very much!
There are likely many options. My superficial sense is that Jaguar does not let these parts get discontinued unless there are options available (or the part is not that critical altogether).
Look into replacing the o-rings you are talking about if the rest of the part is still safe to use.
Other option is to identify the fitting (by name) and have a custom part made. Maybe take a good picture of the fitting reach out to a race shop for help. This is likely a standard fitting that someone in the know would easily identify. then parts are just an Internet search away.
Last option would be to have the fuel rail re-configured with other (more available) fittings. It would likely involve cutting/brazing for new fittings, as a last resort.
Best of luck, keep us posted.
You would think there would be a few options but I have been trying to locate this part for almost a week.
I wonder if changing that O ring is an option.
thanks again!!!
just saw this posted in the SW US Regional section - you may want to try him:
I found a guy that does much of his selling through EBay, however he is local in Irving/Dallas TX. I have been to his location and he has parts for all sorts of Jags, especially S-Types but even newer XJ and XK. He only carries Jag used parts. He gives 30 day warranties.
His name is Michael and the company is:
American Auto Parts
2334 Penn. St.
Irving, TX 75061
469-733-5007
at Ebay he is listed as
Tom in Dallas/Plano
2005 S-Type 3.0 106k
American Auto Parts
2334 Penn. St.
Irving, TX 75061
469-733-5007
usautoparts2
but he generally has much much more at his location.Tom in Dallas/Plano
KnightRider0070 (12-17-2018)
WaterDragon
07-29-2013 11:47 AM
