fuel gauge issue
My fuel gauge is also not correct. Full is about 3/4 and empty, don't know, but I'm guessing around 1/4. OregonJag mentioned: a loose connection to the instrument cluster. I feel this might be true with my issue because it will remain like this for a month or two, then the gauge will "readjust" to a new position and remain there for awhile.
Where can I find the "connection to the instrument cluster?"
I just saw on Motor Week last week that high sulpher in gas can cause the silver in the variable resitance unit to corrode and before attempting a mechanical fix you can try a BG gas additive to remove the corrosion in the sending unit silver to correct the problem. Not sure which additive but the can is gold colored with white letters.
Mike
'00 XKR Coupe
Mike
'00 XKR Coupe
