Fuel Injector Cracked and Leaking
I woke up this morning to the overwhelming smell of gas after starting up the Jag only to find out that one of the injectors is springing a leak!
Has anyone replaced an injector or had a similar event? Things seem pretty brittle down there and don't wish to damage any more of them in the process of fixing the cracked one.
Any help would be appreciated!
Received 4,280 Likes
jobagadonuts (09-28-2017)
Just be aware that early engines have a totally different injector / fuel-rail set up - not sure when the exact changeover date is - around 1999 I think.
On early engines, the fuel rail is part of the inlet manifold and the injectors are fed with fuel from the side whereas later cars have a separate fuel rail and (I think) are "top fed".
If early ones - not that easy to "extract" without damage but if you're going to replace / renew - that doesn't really matter too much I guess. Once the metal locating bracket is unbolted, they just prise out with a bit of help from a couple of small screwdrivers or thin metal levers. There's no separate fuel pipe - it's integral to the manifold.
This will be my first attempt at replacing the injectors on my XK8.
Thanks in advance.
When reinstalling the clip that locks the injector onto the rail - use the upper slot, otherwise the injector will not seat properly on the manifold and you will get misfires
