Fuel and Misfire issues...HELP
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Afternoon everyone
Been using this for help for a while now, so hopefully someone can help me now!
2005 XKR. The other morining trying to start it, as i turned the key, it cranked, then stopped, cranked then stopped...etc. happened about 4 times. Almost like there is a dead spot in the starter.
Finally get it started enough to get it on a lift and looking at it. Was doing a number of maintenance items to it anyways, so i hooked it up to the SDD and it came up with P0112 (fixed), P0102 (fixed) and then every cylinder Misfire except #7. Before i put all the new plugs in, i fired it up to see if i could smell gas, and sure enough, gas was shooting out of cylinder 6 (bank 2, 3rd from the front).
Maybe a leaking injector...?
Any input would be great, thanks Guys
![Icon Worthy](https://www.jaguarforums.com/forum/images/smilies/icon_worthy.gif)
Hi Scott,
Welcome to the Forum. As a Moderator will undoubtedly tell you, introducing yourself in the Introductions Section is mandatory. Your post will most likely be moved to the XK8 XKR (X100) Forum, where you can get the help you need for your platform, 1996-2006 Jaguar.
Also, it will help those attempting to help, to know more about the vehicle i.e., Year, Model, special options, modifications, etc., in the signature line; as well as any service history you are aware of in your initial post. Also include what maintenance you have performed to this point, as it will help pinpoint the problem if it is something that has just surfaced; many things can happen during service and maintenance that will cause all sorts of problems in these vehicles.
Welcome to the forum ScottEnglish,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
jetjack
04-11-2016 02:46 AM
