Fuel odor
There is a fuel temp sensor on the other rail that is worth checking as well, but I don't believe they are a problem part.
Best of luck, keep us posted.
2 of us had the same problem and resolved without any negative effects. 1 removed the dampers and soldered plugs in the cups and I removed the cups and had the holes Tig Welded closed. Either way works but in same situation, I would have plugs machines and soldered into the cups. The dampers are not required for proper operation and there are no ill effects for removing them. The rail material is difficult to Tig Weld due coating and composition. The O-Rings that appear to cause leaks are the same size as the lower injector O-Rings.
This is an incorrect assessment. Jaguar does not offer dampeners for XK8/Rs, but offers them for the S-Type 4.2L, same engine. For the XK8, they say you need a new set of rails, but they are no-longer-available AFAIK. There are a few options:
- See if you want to take a chance with new o-rings. It is a tricky situation as these dampeners are reputedly hard to press back on the rail.
- Find new (or reconditioned, check eBay) dampeners with new o-rings and see how that goes.
- Have a skilled shop weld the (stainless steel?) openings to the dampeners shut. Apparently hard to seal off on the first try. Might require several iterations of plug, cap, etc.
Fuel Rail
defective fuel rail
DavidYau (05-05-2022)
Fuel Rail
Randy
paul-hb
09-23-2024 03:47 PM
