Fuel pressure
I have been fighting the dreaded start run for couple of seconds and die on my 1997 XK8. I checked the fuel pressure today and it was 0 with the key on when the car started it went to 40 psi when it died it went to 0. is this normal? Do you think it could be the ECM? Should I send it to have it checked?
Thank You,
Jay111
Thank You,
Jay111
Where are you taking the reading of 40?
What's the FPR regulator set up on the early cars and have you checked fuel return regulation at all? The fuel pressure should remain for a while after the car shuts down, No?
Also, fuel pump? Has the car sat? Can you hear it?
Are there two pumps in the 97? Is there a way to bridge/jump the fuel pump at the relay so that it runs continuously whenever the key is on?
Yes it's the97, Took reading at the shraider valve on the fuel rail, car sat but all gas was drained ,lines blown out and filter replaced, it ran fine for about a week. Don't know about holding fuel pressure, it goes to 40 psi at start when the engine dies it goes to 0. Goes back to 40psi when it starts back up.
Jay111
Jay111
If I am correct you have two feeds to the fuel pump the first when the key is turned on and the other when the engine starts and it is running. See my link for MY 1999 XK8
JagRepair.com - Jaguar Repair Information Resource
I am not positive that the 1997 is wired the same but I feel confident that it is. I will provide an electrical diagram for your 1997 for you.
http://www.jagrepair.com/images/Auto.../jagxk1997.pdf
If you look on the RH rear of the fuel rail, I think it's near the schrader valve where you took your pressure readings, you should see a vac line plugged into a valve that's bolted into the rail. Is there gas smell or liquid gas in the vac tube?
Received 2,400 Likes
That may be a problem, but I don't think it is your fueling problem.
When you turn the key to on, pos 1, the fuel pump energizes. You should see 40 lbs of pressure. if you then turn the key off, the pressure should remain for at least several minutes.
If you lose pressure immediately, it has to be leaking somewhere. Either a leaking injector, or going back into the tank via the return line, or the pump is bad and not holding pressure.
Without the ecm, you can jump the fuel pump relay for a couple of minutes, then remove the jumper and see what the pressure does.
The following 2 users liked this post by RedSky:
Markmbaha1 (06-19-2022),
michaelh (05-31-2022)
lslincoln
06-15-2022 06:37 PM
