Fuel pump problem (98 XK8)
Wow !!!!!
Had window tint installed today, then had it towed home !?!?!?
After a little investigating, I have reset the emergency fuel cutoff switch (I did feel like it was tripped) no change. Checked fuse in trunk (boot, sorry) not blown but also no power either. Swapped around relays, still no power at fuse.
Any help would be appreciated when I try again in the morning.
Many thanks, Terro
Many thanks, Terro
Power will only appear for a few seconds after the ignition is turned on, then it will shut off for safety unless the car starts. Put the voltmeter between the fuse and ground, then have someone try to start the car. If the voltage appears briefly then shuts off, your fuel pump is likely kaput.
Thanks whitexkr, I had not thought of that. I had thought that they had flooded or washed out the cylinders but was checking out fuel supply side when I got it back home. Hopefully I'll have a clearer head in the morning and have a helping hand trying to start her while I watch volt meter
As a double check, to make sure it is a fuel problem and not an ignition problem, there is a schrader valve on the fuel rail feeding the 8 fuel injectors. If you depress the schrader valve after cranking there should be a strong squirt of fuel. If not, it is another pointer to a fuel pump failure.
Attached are two links one to check the pressure and the other for the power to the pump. Remember you have 2 fuses to the fuel pump.
Link Fuel pressure JagRepair.com - Jaguar Repair Information Resource
Link Fuel pump power check JagRepair.com - Jaguar Repair Information Resource
thanks for all the help. Fuel pump is dead, got it out without removing the tank. It can be done threw the sub woofer hole. It's a coupe so it's a little tight but better than dealing with the lines above the differential, in my opinion. I'm picking up a new one from napa in the morning. We will see how easy it goes back together, although now knowing how it was put together in the first place I see no problem in putting it back in.
Thank again, Terro
Thank again, Terro
On the earlier cars, long period of disuse seem to bring on the failure more frequently.
Charlene n John
09-28-2015 06:01 AM
