Fuel pump relay location?
I think my fuel pump is shot but I want to check the relay/fuses first. I do not have a manual. Can someone let me know where any relevant relays or fuses are.
I drove today and went to start back up and it cranked, started rough, ran rough, and died after 20 feet. No pressure at schraeder when cranking. Fuel filter is 6 months and 2000 miles. I cranked and let sit and cranked again. Not even close to catching.
Also- I have read about the repeated fuel pump replacements and potential ethanol issue. What kind of pump should I get? Original jag? I cannot find a name brand (Bosch or Denso) pump online for my 2001 XK8. Help?
Jacsun (06-29-2013)
You can also download the full Handbook set (Vehicle Literature Pack) for your XK8 in PDF format from:
https://www.jaguarforums.com/forum/x...-2003-a-67827/
Relay and fuse information is in the Vehicle Care Handbook.
Jacsun (06-29-2013)
