Fuel smell in engine bay
The purge valve maybe defective, this is located behind the drivers side wheel well behind the liner, mine was bad and I only noticed it when my tank was less than 1/2 full. I believe on 03 and up there is a cap on the fuel rail that has known to be defective as well, I've read threads previously on this so try a search.
The following 2 users liked this post by jamdmyers:
larueb (10-16-2016),
Orthodixie (05-03-2017)
Just as a follow up, I replaced the purge valve with no impact, so I took it to the dealer. They found the right damper on the fuel rail had a leak. So we fixed that. Problem persisted and found same thing on left side. This makes sense as smell was strongest when I would put car in ACC (pressurizing fuel but not burning). The second leak was tiny and hard to see.
At dealer now being corrected. Hope this solves it.
The following 2 users liked this post by dsd:
BlooDSMeaR (05-03-2017),
If you plan to tackle this yourself (be warned it requires the SC removal), I believe the common wisdom is to send the rails and injectors to InjectorRX where they cap these dampers and clean the rails and injectors.
The key for me was is there a fuel smell before ignition. If so, look at what gets pressurized and holds fuel. The purge valve was easy to replace yourself and it helped me rule out a known suspect.
Best!
What I have found so far is that when I start her up from dead cold, I will get a huge whiff of raw fuel coming in from the ac vents. once its warmed up and driving the fuel smell goes away, or I am becoming nose blind to the scent. Joy oh joy to have the SC off I will want to do a lot of other things while I'm in there. Replacing coolant lines and what not. sending my SC t get polished ... and more and more....
Best of luck, keep us posted.
my 03 non SC xk8 had this gas smell in the motor area. For me it turned out to be the Pulsation dampener on the passenger fuel rail, located in the middle of the 4 injectors on the rail, one on each side. Sorta hard to see as they face downward. My dealer told me it is not a serviceable part and wanted to replace the whole fuel rail for a boat load of money. I was made aware of InjectorRx through this site and sent my complete rail system and the cross over line in the front and had them cap them off. Some try to fix the o-ring in the two dampeners, to which most said they did not hold long. I was told there purpose was more or less to keep the injector chatter if you will, quieter. I heard no diff when I got mine done nor any performance diff at all. It was like 250 for all the injectors to be tested and fixed (cracked plastic bodies on a few, all new o-rings, bench tested and new cross over line (goes from one rail to the other) replaced. They told me these hard hard rubber with a plastic tube in them which I prob broke mine when I yanked on that not knowing it was plastic on the inside. They said it could cause issues down the road. They just put a gas hose in replacement.
DO NOT reuse any o-rings on the fuel rail or regulator, it WILL leak when you pressure it up.
