Fuel Trim Question
Old 09-24-2016, 05:34 PM
jazzwineman's Avatar
Originally Posted by xkrmaxer
Maybe I missed it but what was the RPM on the original freeze frame when the code was set? Also, you said LTFT was +4.6 at WOT. Did you mean STFT? If 4.6 was the LTFT what was the STFT doing at that point?
The codes were a year or more ago - so I cannot answer that question, but were normal for a cruising speed, but cannot remember exactly. The codes at WOT were the LT and short term are zero as the system goes to an open loop on fuel and so therefore the ST would show zero always on open.
Tom
  #42
Old 09-25-2016, 11:12 AM
JagV8's Avatar
Received 4,544 Likes on 3,953 Posts
I think the codes set at 25 (being 25%).
You do have a good battery and have not had it disconnected i.e. have not cleared the trims (so, it's not relearning)? In case it's relearning I'm not sure how much you'd want to be doing till they're fairly stable.
  #43
Old 09-25-2016, 12:40 PM
Battery is essentially brand new. It went down completely by sitting. Codes have been reset and it has had about 8 drives cycles and has learned nothing new from where it started about 3 weeks ago.
We are going to disconnect, reset codes and have him drive it back and forth to work as he had done before the sitting of the car and see if the 0171 and 0174 reoccur.
If, for reason, which on the surface make no sense, do not reoccur and the LT trims stay as high on just simple cruising- then something is amiss.
I took out my own 05 Stype, albeit a different car (had disconnected the battery and cleared the codes (p1111), the system, like the XKR, is still trying to adjust to the 14-1 ratio and my fuel trims, even on the first drive cycle my fuel trims went exactly to where they had been for the last 25,000 miles.
So what would you deduct from the +15.6 and +16.4 LT trims at cruising at almost any speed?
Tom in Dallas
  #44
Old 09-26-2016, 01:23 AM
JagV8's Avatar
Insufficient data on their own - could be anything from a fuel problem to blocked cats.
yeldogt
08-28-2016 11:39 AM
Peter Jones
08-24-2016 08:12 PM
2005-Jag
08-24-2016 06:05 PM
jorge911
08-23-2016 11:34 AM
Joseph12
US Northeast
08-22-2016 02:22 PM
Quick Reply: Fuel Trim Question
