Fuel Trim Question
#41
The codes were a year or more ago - so I cannot answer that question, but were normal for a cruising speed, but cannot remember exactly. The codes at WOT were the LT and short term are zero as the system goes to an open loop on fuel and so therefore the ST would show zero always on open.
Tom
#42
#43
We are going to disconnect, reset codes and have him drive it back and forth to work as he had done before the sitting of the car and see if the 0171 and 0174 reoccur.
If, for reason, which on the surface make no sense, do not reoccur and the LT trims stay as high on just simple cruising- then something is amiss.
I took out my own 05 Stype, albeit a different car (had disconnected the battery and cleared the codes (p1111), the system, like the XKR, is still trying to adjust to the 14-1 ratio and my fuel trims, even on the first drive cycle my fuel trims went exactly to where they had been for the last 25,000 miles.
So what would you deduct from the +15.6 and +16.4 LT trims at cruising at almost any speed?
Tom in Dallas
#44
Peter Jones
08-24-2016 08:12 PM
2005-Jag
08-24-2016 06:05 PM
