Fuel Trim Reports constant 0
I have a '00 XKR and am getting codes 171 and 174 meaning the engine is running lean.
I have an OBD2 scanner and installed Torque on my Android phone so I can do the "spray method" of finding where the air leak might be.
However, the Fuel Trim sensor readings on Torque are a constant 0. The O2 sensor display, however, registers values.
I've seen at least one video where people show the STFT display and how it changes if something is sprayed near the leak. What am I missing?
I visually inspected the intake valve, breather hose and they seem in really good shape. The part-load valve is also clear. Any suggestions?
The dealer said I should replace the valves, seal and hose, but they look fine. Should I just do it anyway?
I agree, but seem to have little choice. I ordered the parts ($100) and will replace them even though they look good. If it doesn't work, on to a smoke test or something else.
Bob Gelston
09-14-2015 11:08 PM
OkieTim
09-08-2015 04:48 PM
