Fuel trims
Dale Dunn (03-17-2017)
Received 2,190 Likes
Mass air flow sensor, part load breather, cam cover leak, missing oring on oil dipstick. cracks in air intake tube or full load breather. Just monitor your full trims and spray areas with carb/brake cleaner when they start pulling you've found a leak. past this I would say your injectors have a crappy spray pattern. I would pull them(easy) and send them off for rebuild, cleaning and flow testing like to www.injectorx.com
![Icon Nic](https://www.jaguarforums.com/forum/images/smilies/icon_nic.gif)
This should be the first post on every Fuel Trim problem! We miss you Brutal!!
Mass air flow sensor, part load breather, cam cover leak, missing oring on oil dipstick. cracks in air intake tube or full load breather. Just monitor your full trims and spray areas with carb/brake cleaner when they start pulling you've found a leak. past this I would say your injectors have a crappy spray pattern. I would pull them(easy) and send them off for rebuild, cleaning and flow testing like to www.injectorx.com![Icon Nic](https://www.jaguarforums.com/forum/images/smilies/icon_nic.gif)
Brutal (03-20-2017)
