Full Jaguar EPC Download, with complete install instructions.
Brought to you by BuckMR2, hosted by me. This started in the X-Type section, I moved it over to the S-Type section, but I wanted to share it with the rest of the guys with other models as well.
Please don't link this to other sites or be ridiculous, this is on one of my personal servers. About 50mbps Bandwidth.
Completely Edited now with screenshots and step by step install instructions. These instructions are for windows 7 32 bit. No difference in 64 bit EXCEPT you have to enable the 32bit browser as default!
First, before downloading the file, you need to make sure you have winrar installed. This is the program that you will use to extract the files to your computer.
You can get winrar free of charge from here:
IF you have a 32 bit operating system, Click on this link:
http://www.rarlab.com/rar/wrar393.exe
IF you have a 64 bit operating system, click on this link:
http://www.rarlab.com/rar/winrar-x64-393.exe
Once you have winrar Installed, click on the link to download the EPC.rar file:
http://www.itprosondemand.com/jaguar/EPC.rar
Save the file to your desktop just for convenience. You will be deleting this file when you are finished.
Once the download has finished you will see the following icon on your desktop:
![](http://www.itprosondemand.com/images/icon.jpg)
IF the icon doesn’t look like that (The 3 books stacked like that), you have not properly installed winrar, you need to repeat step one.
Double Click on the EPC.rar icon and winrar will open, at first at the lower left you will see it counting files, once it is done, you will get a menu that this is a trial version, just click on close.
Then You will see this:
![](http://www.itprosondemand.com/images/winrar.jpg)
Click on the extract to on the top left:
![](http://www.itprosondemand.com/images/extract.jpg)
The extraction path and options menu will come up – leave the defaults and say OK.
![](http://www.itprosondemand.com/images/extractmenu.jpg)
This will pop up and it will extract the files – this may take a little while
![](http://www.itprosondemand.com/images/extracting.jpg)
Once the extraction has finished close winrar.
You will have the following icon on your desktop:
![](http://www.itprosondemand.com/images/EPCfolder.jpg)
Double click on that folder and you will see the following folder:
![](http://www.itprosondemand.com/images/1st%20Level.jpg)
Double click on the folder “Jaguar Epc v3 10.2009” You will see the following window:
![](http://www.itprosondemand.com/images/2folders.jpg)
First take the JEPC Shortcut file and drag it to your desktop.
Then CLICK on the JEPC folder, hold down control and click on the jepcv3 folder (so both are highlighted).
Right click and say CUT. (or press control X)
![](http://www.itprosondemand.com/images/cut.jpg)
Now go to computer (or My computer in XP)
![](http://www.itprosondemand.com/images/computer.jpg)
Double click on c:
You want to be in the root of c: (your icons will be different, BUT the key is across the top that it says computer -> Local Disk (C: ) ->
Right click on a blank part of the window and say paste:
![](http://www.itprosondemand.com/images/paste.jpg)
The computer will move the two folders from your desktop to the c: directory
![](http://www.itprosondemand.com/images/moving.jpg)
When it’s done you should see these two folders in the computer -> Local Disk (C: ) -> window.
![](http://www.itprosondemand.com/images/copied.jpg)
Now double click on your JEPC Shortcut icon on your desktop:
![](http://www.itprosondemand.com/images/jepcicon.jpg)
IF all went well this will open up.
![](http://www.itprosondemand.com/images/login%20page.jpg)
Type Admin in the login field and 123 in the password field - click login, and the main menu will come up:
![](http://www.itprosondemand.com/images/main%20menu.jpg)
Then select the model / year, and go from there.
Hope this helps with all the install issues.
Feel free to ask a question if you have one or need help, BUT please post it here, that way I don't have to answer the same questions repeatedly, and others can read it here rather than waiting for me or others to respond.
Take care and Enjoy
George
Double click on c:
Take care and Enjoy
George
As a 'service' to the forum community, these model threads will be up for a short time, then the link to a main thread (most likely in the General Tech Help) area will remain, open for replies.
After that, these threads will be deleted to keep things clean. I am keeping them closed so that all the threads are not bumped with questions and replies. If you would ilke to comment, please see the original thread.
Fraser Mitchell
10-01-2015 04:06 AM
