Full Load Breather Hose and Codes P0171 & P0174
Old 04-17-2011, 06:58 PM
beg3yrs's Avatar
Default Full Load Breather Hose and Codes P0171 & P0174
Traveling about 75MPH yesterday (legal!) and Restricted Performance showed up for about 10 minutes. Went away but left the Check Engine (MIL) light on.
Still on today so got the freeze frame codes and saw both banks were running lean (thank you AutoZone for the OBD2 loan).
Visual inspection of the engine compartment, focusing on the air system and noticed the Full Load Breather Hose has a busted connector at the air intake tube end and was only partially inserted into the tube. Do y'all think this could be the cause of the banks running lean?
I've ordered a new hose and Gorilla-taped up the busted end for now.
Old 04-17-2011, 08:37 PM
Reverend Sam's Avatar
Received 1,261 Likes on 565 Posts
That sounds like a very likely culprit. Clear the codes and see if it comes back now that it is sealed.
Old 04-17-2011, 08:39 PM
Spurlee's Avatar
That's the problem. Easy fix.
clubairth1
29
05-10-2024 12:57 PM
Bcrary3
02-21-2023 04:29 AM
OkieTim
09-08-2015 04:48 PM
hen555
09-07-2015 11:13 PM
OkieTim
09-02-2015 12:48 PM
Quick Reply: Full Load Breather Hose and Codes P0171 & P0174
