full load breather - no orifice on 03XKR?
I was doing the throttle body and full load breather cleaning as described here on the forums for the 2000 XKR....when I removed the full load breather connections, there was no orifice on the valve cover side?? Is this the case for a 03 or was it removed or???
On the left hand side cam cover the part load breather nipple includes a 3/32" orifice that is located about 1.25" down inside from the top of the connector. If yours does not have that you will have to replace the engine.
Either your orifice is completely clogged up or I hope this is a communications problem!
Illustration 4 of the JAG TSB on this shows it perfectly
the hole/orifice is in the tube that leads down towards the valves, appears to be a metal cone like thingy
I will look harder later. Thansk for clarifying and being patient with me!!! I have had the car less than a month and have been learning and doing a ton of reading!!!!!
I also have a 2005 XKR and, like Goldlion, I definitely do NOT have anything that looks or sounds like what was described in the how-to about cleaning the part load breather (mine looks exactly like Goldlion's). I think I asked about this a couple of years ago when I first bought my car and someone said the later models do not have the same setup as the older ones.
Doug
Doug
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
