Fuse fir primary instruments
Thanks for the info. It will be helpful at another time I'me sure. But the fuse is not the problem. The problem is in the ignition switch. I have had problems there before that I have put off and have just pulled the just for the radio. This time it is definitely the ignition switch. When I put the key in and turn it up as far as it will go without starting the engine all lights come on. Releasing the key position back to run position the lights go off. Going back up lights on. Back to neutral lights off. I am thinking of spraying the switch with some tuner spray. If that doesn't work I will remove the switch and give it a complete cleaning.
I will keep you informed.
