Fuse location for convertibale top?
Your windows will not go up until the latch is completely latches at the header. It sounds like either your roof is out of sequence or you have a hyd leak. Do you have evidence of a leak and do you know where your pump is? I have a lot of information on the roof system on my page if you wish to read.
The fuse is located in the trunk and you have relays for the roof. Not knowing the year of your car you can select it at http://www.gusglikas.com/AutoRepairElectrical.htm for the fuse and relay location is in the trunk next to the battery. As for the location of your pump it is in the right rear above the CD. This link might help you to get access http://www.gusglikas.com/AutoRepairJ...esRelValve.htm Now in the shelf of the pump you will find the allen wrench. This wrench is used to manually open and close your header latch. Your windows will not open or close until the system is completely satisfied and a leak or low fluid in the system will prevent this from taking place. http://www.gusglikas.com/AutoRepairH...lOperation.htm Read the last paragraph.
Thanks for all your help, Gus! But after having no luck diagnosing the problem myself, I finally took the car to the Jaguar mechanic today. He found the left side ram was leaking fluid. He's replacing both rams as well as flushing the system and adding the newer hydraulic fluid recommended by Jaguar.
Thanks again,
Ray
Thanks again,
Ray
aholbro1
08-05-2021 05:02 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
