Fuses. I Need A Chart Of Location
What Ho Chappies
I am trying to figure where and what fuses locate in the boot fuse box.
It would appear that in an attempt to increase dividends to shareholders, Jaguar put a sticky label thingie on the fusebox cover.
However, this has vanished and Jeeves and I have a bit of a problem.
Is there anywhere I can find a fuse chart for the dashed thing.
XK8 2000. and all that.
What Ho
Bertie
What Ho
Bertie
Received 6,319 Likes
Norri
They just dont make minions like they used to.
Your honor, in my defense, I do understand the fuse number, the rating and circuit but with two rows of fuses do the numbers run from left to right or right to left and does the number 1 fuse reside on the end of the top row, or bottom. Dashed if I can see any branding in the box.
If the window is blowing fuses it could be because the operating cable has become entangled. This was a common problem due to the flexing of the winding frame only fixed after about 4 years of field trials. Jaguar must use their customers for more design testing than any other car manufacturer.
Well, I put my spectacles on, took a bright light and low and behold I could see little tiny numbers beside the fuses.
Bit embarrassed here.
What a silly ****.
Thanks to all who responded.
Was checking because my passenger rear window is not closing but stuck half way.
Tootle pip
Bertie
What a silly ****.
Tootle pip
Bertie
jimforrest (uk)
02-28-2019 06:42 PM
FS[SouthWest]: 19" Aquila Wheels with Tires
jorgef858
01-14-2016 11:32 AM
