garage door opener
I remember having a little trouble when we did it, it took liek 20 minuets to program the garage.
I don't remember specifically what we needed to do to make it work, all I remember is that we weren't doing exactly what the manual said.
This will sound like bad advice but just try reading the instruction more closely and doing exactly what it shows, or have someone else do what they think it says to do.
My dad spent liek 15 minutes reading what the owner manual said and he couldn't get it, so then i read the instructions and got it on my first try i believe.
SORRY i cant be more helpful
This one is actually easy. The manual confuses you and tries to tell you about using the programming button on the actual garage door motor/panel. All you have to do isbegin the programming ofthe button on the jag panel, as the manual says, and activate (&hold) the remote next to it, and it will recognize the correct frequency, if after 5-10 seconds, that is. Hope that helps!
99xk8guy
06-05-2023 06:28 AM
