Garage opener lights do not blink
You don't have to clear old homelink codes to program new codes. Clearing is for when you sell the car, so the new owner can't open your garage.
Your garage door opener won't learn the homelink code, until you feed the homelink the code from your remote. Hold the remote button and the homelink button to be programmed at the same time and hold until the light rapidly flashes... THEN you can push the program button on the opener, run to the car and push the Homelink button, hold for a couple seconds and release. Do this two more times and the garage door should close.
I have an older garage door opener (Liftmaster) from 2000. I double-checked the openers' original instructions...1)press the "learn button" on the opener itself (a red button on my unit) with the car parked in the garage (had to climb a step ladder to reach the button); 2) you then have 20 seconds to press the preferred opener button in the car;3) the light on the garage opener (that's the light on the opener mechanism, not the little light in the car) will blink twice and your code is set.
Ungn (05-05-2016)
Your 2000 opener may be rolling code. My five 2001 Liftmaster openers are all rolling code. A 1998 XK8 Homelink is more than likely not rolling code.
I swapped out my non-rolling code 1997 Homelink for a Rolling code Homelink I purchased on Ebay for $20. For the last 20 years the Homelink cases haven't changed much so even the brand new ones physically fit, but you may have to do a few tweaks due to the button length.
I put some picture of the mod in the How to/DIY Sticky for Homelink.
Let me reiterate... I have a '98 XK8 Coupe. I have a 2000 garage door opener (I unfortunately only have one). The Homelink instructions didn't work with my set-up; I tried the remote to Homelink method without success. All I can tell you is that I was only able to program the Homelink function in my car by following the procedure I described in my earlier post. I believe if you do some research in the Forum you'll find other discussions and similar solutions.
Snookfever
11-13-2019 07:53 PM
pwpacp
05-12-2016 11:11 AM
