gas additives
tony bosco (02-09-2015)
Received 2,263 Likes
No additives are required for any vehicle with a sealed fuel tank as found on any modern car.
Do NOT start the engine unless you're taking the car for a good long drive. Doing so causes condensation and acids to collect in the engine and exhaust. Attach a battery tender and let the car enjoy it's rest.
Agree with above posts. You really don't NEED an additive for a couple of months off the road. Condensation is the big worry. Keep tank full. And if you do start it, keep it running until you can touch the rear exhaust tips and they are HOT. Also if your baby is left outside covered, be sure to find a cover that is breathable. Do NOT use a plastic tarp or anything that will not let moisture escape through the covering. Also try to park off the soil and on concrete and if on concrete, that is where you can use your blue tarp. its all about moisture control... and rust. gordo
My Jag sits for 6 months every year, I use Sta-Bil, and a battery maintainer (get a good one that shuts off when the battery is fully charged). If you use gas additive make sure you let the car run for 10 min so it propagates through the fuel system. Like the others above I don't recommend starting it weekly.
