gas leak injector rail damper
I have a 2003 XKR with 68000 miles. I am leaking a little gas along the rail on cold startups. I am pretty sure it is the problem of deteriorated o-rings in the dampers on the fuel rail that has been documented so well by MAXDAWG. Is it still the preferred solution to remove the induction system send the rail and injectors to InjectorRX in Houston, have the dampers sealed and reassemble?
Dave A.
Dave A.
