Gasoliine Fumes in XK8
I have an XK8 convertible, 1999 just turned 60k miles. I have been getting gasoline fumes in the car on and off for months now(more off than on). There is no visible signs of a leak, no drips from under the car or in the engine compartment. There has been no change in the performance or fuel consumption. Any ideas of the problem or fix? Help please!!
Received 2,191 Likes
The tank is in the trunk so leakage is gonna be strongest there if its leaking vapor. Pull back liner and inspect. Past that the other areas are the cannister close valve that vents by the right rear wheel well. And the purge valve underhood. Another common leaker is the short stub hose between the right charcoal cannister and the close valve. It cracks, but many of these issues will kick off a check engine light for evap system leaks
Received 9,008 Likes
mikiep
12-20-2019 07:37 PM
Pristine97XK8Convertible
04-28-2017 11:08 AM
