Gave my local dealer my VIN and many ??'S
The Direct Dealer Warranty - Vehicle Details
Paper work shows I have a AC w/Air Filter. Mind you my car is a 1997 with a birth date that appears to be 12/23/1996 and sold on 2/14/1997.
Should I take this print out as gospel that I have this cabin filter??? It would explain why I have ALWAYS felt that this blower fan on the HVAC was really lame. It blows it hardest that would match any of my ither cars low to MAYBE med at best.
It also says I have Head Lamp Power wash but can't say I have ever seen anything squirt on the head lights!!!
Everything else on the print out about the car is correct.
The only reason I knew I had headlight washers was because one of them was misadjusted and it squirted straight up in the air. The headlight washers work when you activate the windshield washer. Have someone sit in the car and hold in the washer switch while you watch from the front. After about 5 seconds the headlight washers should come on.
Cars are considered classics after 30 years. You're almost halfway there.
The 'casual part number' is intended to be a significant part replaced under the Jaguar warranty. It may be only one of many dealt with on this repair but all that is buried within Jaguar's data base as far as this report is concerned. Use one of the part number look up sources to get an idea of what was repaired.
Tim
Take a look at your headlight, if you have power washers there will be a little glass door at the bottom( it will actually move), if not the glass door is actually molded into the glass headlight cover, I would also like to see a list of the dealer codes and what they mean.
Doug
2001 XKR Silverstone
Doug
