Gave my local dealer my VIN and many ??'S
#41
Well I pulled off the little plates that cover the light washers and now they don't seem to go back on very tight, drivers side more then pass. They go on but seems to be one good bump and they are gone.
I pulled out the little device that squirts and both left and right side appeared to have only one nozzle (missing one on the right side as you look at the arm/socket nozzle holders) in the two front sockets of the arm that comes out. Should there be two nozzles in the sockets on the arm that pushes out??
#42
Tim
Then washer unit slides into the bottom of your headlight assembly if you can reach up from underneath and grab the washer unit while pushing the cover back on it will snap into place, its held on by the nozzle. You may have to loosen the fender liner to get to it.
Doug
XKR Silverstone
Doug
XKR Silverstone
#43
Well I got the light washers to come on. They sure do flick out far and sprayed water all over the hood. HA HA HA. I am assuming the covers that connect to them will redirect just ot the head lights?
Still seems to me some nozzles are missing. The thing that pops out, on the end there are two sockets, and on pass and drive side there is one empty socket on the right side of arm. Anyone know anythign about what should be there????? I need to snap some pics to show you all.
